On 1/15/2025 at 11:43 AM, Joey Mack said:
Is bearing pre load between.003"+.006"? Are you able to buy shim paper and cut your own shims.  Ive done that a couple times.. just need a scissor..
joey are you talking shim paper or shim steel?  Terry:MackLogo:
Larry if you do decide to use this trans behind the 285 i'm guessing you still are using the single disc clutch don't let it lug mine with the 260hp. and triplex will slip the disc if I'm not careful if it gets down in rpm and I give it too much throttle too quickly it happened coming back from Macungie
Seems like it is from research I found.  Which is fine since I have a triplex.  I think the truck, being a fleet truck, speced it with just a 5 spd.  Not optimal but Mack must have okayed it.
I've seen other older fleet trucks with 5,6,7 spd transmissions on cat and Cummins.
I’m sure you probably know this, you have to bolt cases together to set endplay on counter shafts and shim accordingly,check at pto opening, and I believe on mainshaft output at back box takes spacers between the two facing bearings to set endplay.  Terry:MackLogo:
25 minutes ago, Freightrain said:
Kevin All had a few and was sending me a better TOB carrier.  Should be here in a few days.  I was going to cut my own if I had to.
Yeah long as you got one for a pattern shouldn’t be to hard.  Terry:MackLogo:
