2011 GU713 quad dump, mp7 405, maxitorque t310m
Alright, I'm starting to work on getting my old dump back up and running, old girl needs an engine, and the trans has a problem with not going into high range. So at this point I'm looking at buying a whole running road tractor to get the needed engine and a spare transmission, and I wouldn't mind bumping up to an mp8 505, not to mention parts prices (engine specifically) are ridiculous compared to buying a truck I can drive and see how it runs.
So after a small backstory here is the question. Let's say I buy a 2010 or 2011 with an mp8, would the emission equipment be the same and work with no programming to the mp8(dpf is the huge stand-up system behind the cab that looks like a muffler)?  That's my biggest concern on the swap that I'm not sure of, hopefully someone will know.
https://www.bigmacktrucks.com/topic/75018-installing-an-mp8-in-place-of-an-mp7/
2011 to 2011 emission should be same.  Not sure about 2010 to 2011.   I vaguely remember that 2012 was the year of an emission change.
But, for the MP8into your truck you will need the ECU reprogrammed.  If you use the ECU that came with the MP8,  then you will need the rest of the truck reprogrammed as the VIN/chassis is in the different computers that run the truck.
