I’m having trouble I recently been losing air pressure every time I push in my yellow brake valve it sounds like it’s loosing air I check the valves and found that it was leaking from a valve under my cab, then it went away and now it looks like it transferred over to another valve under the frame by the rear drives any ideas what it may be need help thanks
https://www.bigmacktrucks.com/topic/75038-brake-control-valve/
Are you able to hook shop air to the first air tank, chock the wheels, and release the brakes so you can locate leaks ? This will allow the engine to be off. Nice and quiet....
https://www.bigmacktrucks.com/topic/75038-brake-control-valve/#findComment-567116
