The two tanks should be T'ed off of the wet tank. So a stuck check on the inlet (not likely) or a leak at the the brake treadle valve or other  part of the primary system. Plug off the outlet of the primary and see if it builds.
https://www.bigmacktrucks.com/topic/75055-mack-midliner-cs300p/#findComment-567350
Hey brother had a family emergency so I didn’t get to mess with it today. Will block off the primary tank and get back to you
https://www.bigmacktrucks.com/topic/75055-mack-midliner-cs300p/#findComment-567832
  • 2 months later...
Sounds like the brake treadle valve is leaking. Check for air leaking out the bottom of the valve (floor mounted) or back of valve (firewall mounted).
Kits are available for both types, but most just buy a reman and slap it on.
https://www.bigmacktrucks.com/topic/75055-mack-midliner-cs300p/#findComment-573747
