Sitting in line at the elevator I’m noticing my temp gauge bounce around pretty erratically. Noticed it reading a little higher going down the road earlier so was worried maybe thermostat but now that I’m watching it it looks like it’s moving too fast for that. Are these gauges mechanical or is there a sender somewhere to look for?
I should add, to check the gauge wires if the sensor wires are ok, if its a single pole sensor, see if the post wiggles. Fast moving needle is commonly an electric issue, temp change is slow via thermostat.
