Is the play in the steering box? Have you added up all the play in the steering shaft joints? Have you looked at the spring u- bolts to see if they are loose, and the axle is sliding slightly? Also check all the ball joints in the drag link and tie rod, Its odd that a rebuilder would put a worn worm gear and sector shaft back in the box.  Good luck 🤞
