Missing the warning lights under the speedo/tach.
Last time I had to buy a pump it was $1600 also. It died under load, pump shop said he never saw a pump with so much broke in it come off a running truck!
I did my own pump as long as there weren't broken parts, but this one was done!
1 hour ago, mechohaulic said:
amazing how a "little thing" : like heart surgery  can change a persons plans.!! I have doubts for even driving from CT to NC . I found a neat T shirt states "body parts original ;; "power plant " rebuilt.  back to topic ; real nice truck,
Thanks, I like it so far, haven't got to drive it much yet, but hopefully we can get in it and go places. I told little Miss speed demon that it doesn't seem so slow when you're in it 🤣
  • Haha 1
4 hours ago, harrybarbon said:
Congratulations, now you need a trailer for the Inter to go to the shows this summer. Tom is it a sleeper with 1 or 2 bunks or 1 snug bunk 🤔👫
It doesn't even have a bunk, it's got a couch all the way down one side, then on the other side there's a refrigerator, microwave, sink, and a little triangle shape seat in the corner. It has a window type AC unit in the back. It was set up really nice at one time, it had a hook-up for a Kohler generator to power everything. 2 different size hitch balls and a small 5th. wheel. I talked to Rob and he said he was pretty sure he had seen that truck in Indiana getting fuel at the same place he was, and they were delivering new camper trailers with it.
So the sleeper has lots of potential, but it does need a new boot, I saw a couple of holes in it.
The guy that I bought it from, who was going to drive it to Vancouver, bought it from a guy who had it on the farm somewhere. He might have used it to pull a livestock trailer or something, I don't know. It looks like it's been pretty well taken care of though.
  • Thanks 1
Yeah, it’s a nice looking ride. I only drove one of those one day around 1977. It was a Hertz rental Detroit with a 13 speed. It’s a good thing you’re not looking for a fuel pump for aMack they are three times that price good luck
Does anyone remember when the L-10 came out? I don't remember seeing it before '83 or there abouts? 1974 sounds too early for it to be original.
I drove one 300hp, 9 speed geared about that for top end. It has a RTO 9. It would run in the 6's MPG loaded.  No power house by any stretch, but it did ok.
I don't know a thing about them, but everybody (whoever "everybody" is) says they're a good engine, pretty much bullet proof. It would be nice if this one had a 9 over, then it might run fast enough for Zina. I knew it wasn't going to be very fast as soon as I saw on the sticker on the back of the visor that it had a 4.11 rear end ratio.
4 minutes ago, Geoff Weeks said:
I thought so, thanks. But gets a few facts wrong. The L-10 is 611 CID, and the M-11 is 663 IIRC.
Oh, I see what you're talking about now- the truck is an '84, not '74. That's a misprint, due to big fingers, arthritis, and small screens.
I shall go back and fix that right now.
I worked where we had two Volvo/GM's one had the 300 L-10 and the other had 855 365hp, not a fair comparison, and the 855 had the 13 spd while the little L10 had a nine. They also had a 3306 powered tractor at 300 hp, and I would say I like the cummins a bit better than the small Cat.
 Cat lost the timing gears and did a lot of damage, the L-10 had a slight head (coolant) leak for years and finely ventilated the block.
Like many smaller displacement engines, they were often asked to punch above they're weight class.
The L-10 head is a bear to lift off as it is all one piece of iron.
I think a fair comparison would be L-10 vs.6-71 Detroit.
9 minutes ago, Joey Mack said:
Its a sweet looking truck... You did good again.  I may come see it at Colfax next year, if you go again..
Sounds great- who knows, we might take a notion to ride down to Bill's Truck Stop for lunch one day.
1 minute ago, Geoff Weeks said:
If you have the CPL number I can lookup how it came from Cummins.
I have the VIN on the title.
No, the CPL is on the engine tag. It relates to the parts (pistons, fuel setting etc) that were used on that engine.
You can also look on the fuel pump tag, and if it is original it will have the CPL on that tag as well, replacement pump more often have the "fuel code" in place of the CPL on the fuel pump tag.
