Question
Sorry it’s a 2004 not 2006
IMG_3884.thumb.jpeg.b0b83e7346f07b3d5185878f63aedab4.jpegIMG_1230.thumb.jpeg.0805c89933755f6a5f87579c8282db51.jpegAny Mack gurus in here that can help me motor wise.
I have a 2004 6 axle Mack that I inherited and I bought a new motor for it. The old motor both heads covers were stolenn off so I don’t know what hp or serial number on it. I hired a company that has since shut down by the IRS to replace the motor. Before hand they bought a new motor. Now I’m having issues with other mechanics saying it’s not the same motor and that water pump location are different. I contacted the companyc CA trucks that sold the motor and they say it will work. Other mechanics say it will but will be to much money to customized it. I was under the assumption it would be a drop in motor. Can anyone help me and tell me what motor I have in it just from the pictures? I know it’s crappy photos but it’s all I have. One from before they pulled it and several as it sits now. Is it worth it to continue to even pursue it or just sell everything? I’ve been trying for almost 9 months to find someone who will agree to work on the truck. Most deny bc they don’t like working behind another mechanic when the old motor was pulled. Some pics of old motor and new one are posted
Edited by BobbyCTX
https://www.bigmacktrucks.com/topic/75179-which-motor-do-i-have/
  • 0
21 hours ago, Joey Mack said:
I had to read this twice . And correct my correction of myself.  Old engine is either E-Tech or CCRS.  new engine is ASET-I. If the truck is an 04 then the new engine is what it was born with.  The fan arrangement is no big deal. The mount you need can be set to the correct height for the fan shroud.
Guess I’m still a little confused about this statement . Your saying if it’s an 04, which it’s is,The newer motor is the aset, iand is what it was born with from factory. And my old motor is an etach motor. Are you saying that it was prolly changed before hand?
Edited by BobbyCTX
  • 0
11 hours ago, BobbyCTX said:
Here’s the vin
1M2AG11C54M011147
thanks
@The Heinz can you check this out when you get a couple minutes. Let's try and figure out what's supposed to be in there, then we can work out what can be done with what you have.
  • 0
The AI engine is almost identical to ETECH engine.  Only differences are the AI has an extra bump on exhaust loves to crack exhaust valves open during intake, to suck partially burnt combustion gases back in,  AI has restrictive exhaust manifold and turbo to create back pressure to facilitate the above; the EUPs are definitely CCRS on the AI, whereas they aren't all CCRS on the ETECHs.  CCRS is Current Controlled Rate Shaping:  the EECU fires the EUP in 2 phases to better control fuel burn.  Pre-CCRS engines the EECU sends signal and fires the fuel into the cylinder in a single burst, rather than phasing it in.  Minor fuel return differences from the heads, heads are not interchangeable between CCRS and Pre-CCRS without fuel return modification.
Great news is you are dealing with the AI family of engines which is much better than the AC.  You can delete the emissions EGR by putting an exhaust manifold and turbo on from a pre AI engine, and if you ever need to replace the camshaft you can put in a pre AI cam as well, though you need to research your cams first because there are differences in cam gear keyway positioning.
  • 0
16 minutes ago, JoeH said:
If you were close to me in Southeastern PA I'd consider taking this project on.
It has the Allison trans in it. And how far is that from DC. At his point I’m not oppose to anything to just get his done done honestly.
  • 0
Just a quick thought....What is on the back of the truck? Any type of specialized body? depending on build date, a 2004 Granite is nearly 26 years old at this point. If its just a chassis then good/decent, inspected, and running examples are a dime a dozen at this point. Is this job even worth the money and effort? Obviously you already own a "new" engine so my question my be moot if you can't return it for a refund. Not being disrespectful but just looking at the big picture.
  • 0
My zip code is 18914, you can check distance from me.  My busy season is getting ready to start, I'll message you my cell # if you want to talk over what's going on with it.
  • 0
On 2/18/2025 at 6:37 PM, Mackpro said:
The truck a CV713 or a CXN/CHN?  Looks to be CV700 series by the steering gear box.  If it in fact a 2006 CV 7XX  series truck then it should have a ASET AI engine. By the looks of it , it has a ETECH /CCRS  engine installed which is the wrong engine for this truck to begin with. The engine you bought is a ASET AC engine which in not correct  for a 2006 CV 713.  The ASET AC engine is for 2003.5 to 2007 CH/CX and CXN/CHN  trucks. The ASET AI engine is for 2003.5 -2007 CV, MR and LE trucks. The AC engine has a VGT turbo , external EGR cooler and engine ECM has 3 plugs. The AI engine is more like the ETECH engine with a 2plug engine ECM.
Am I able to just switch the ECM to get it to work
  • 0
So the "new" motor is definitely an AC? Have never seen one, we weren't blessed with them over here in Aus.
Anyway, regardless of what it is, someone has put considerable effort into making that engine look "new". Couldn't replace a hose, but painted all the bolt heads, fan mount faces and a few nuts silver🤦🏻‍♂️Screenshot_20250225-115718.thumb.png.165f048cd6a9f76e52ae1da8e3741651.pngScreenshot_20250225-115811.thumb.png.95dd6c3b4bd6bc3155aedad20991e836.png
Without pulling it down, it's nothing more than an expensive boat anchor. Sorta like putting lipstick on a pig. Just sayin.
  • 0
Here's a question for you @Joey Mack; can he block off the EGR crap on an AC motor, and swap on the wiring & electronics from the AI and call it an AI? Could go a step further and swap whatever exhaust and intake manifolds are needed from the AI to complete the EGR delete.
  • 0
He could leave the EGR crap on there, it wouldn't be functioning if he could use the AI engine loom and ECM. Providing they use the same sensors and EUPs I couldn't see it being an issue. Cam timing may come into play?
Don't the AI have the restrictive exhaust manifold, and the extra bump on the exhaust cam? To facilitate the IEGR.
  • 0
JoeH,, i don't know.. i have never done that. I would think stripping all the ASET-CEGR bolt ons would have to go, and possibly a cam shaft change , maybe not. Yes the exhaust manifold is restrictive. An EECU and harness swap would probably work as well.  Sorry. Ive done a lot of these rebuilds, but only used OE parts. Kinda wish I was able to try things, but my job was to put the money maker back in the road ASAP. mods come with trial and error... I say a full strip down then build an ASET-I would do it..
  • 0
As far as leaving the EGR COOLER in place,  i guess i would want to remove it, so there is no air or coolant flow.  Not sure about blocking it.  I did work on one years ago, where someone made a plug to block the crossover EGR tube, and it was inside out of sight.
  • 0
Removing the extra bump and the restrictive manifold are hardware changed you can actually do to delete the AI EGR system.  There's nothing computer related to the AI EGR system.  Does the AC use a variable geometry turbo?  I know the AI is fixed.
  • 0
@JoeH @Joey Mack so it is safe to say the “NEW” motor is 100 percent an AC motor? And it would probably be to much work and not cost effective to swap everything needed over to make it work? What’s your guys thoughts.
So from what I’m what I’m reading from you guys and what the VIN number pulls is that it came from the factory with a ASET AI 350. But the old motor that came out of it wasn’t even a ASET AI. So at some point that means this motor was replaced before with an ETECH? And even if I got an AI motor that it came with from the factory will that work with the current pcm, ecm etc… I really wish I could find someone to put this thing in for me or give me a solid answer on what exactly I need. And you guys have been great help. I really wish I could get the serial tags that were on the heads of the motor that was pulled so put an end to the question of what came out
  • 0
Pull the front cover off the new engine and get the cam number off the cam shaft.. its right there... No need to pull the cam.. then run the number... A stripped A-I and a stripped A-C look the same... It is an ASET... cam number should tell you which one..
Answer this question...
