Question
5 answers to this question
  • 0
Are you having trouble getting one using the vin. ?  Do you have an issue bigger than just a leaking seal ? Do you have it apart yet ? The seal number is on the inside if the seal. I expect it to be a Stemco Voyager series with the inner seal ring that has a dowel pin to isolate it.
https://www.bigmacktrucks.com/topic/75204-hub-oil-seal/#findComment-570126
  • 0
Hey Joey how are you doing,,, everything is fine but I went on to work yesterday Saturday but unfortunately when I got to the yard and was doing a post trip I saw that front wheel seal was leaking but the mack dealer was already closed so the only option was a parts store that was about to close also, that's why l was trying to get the part number because I wasn't going to be able to take it apart, but I'm going to have to wait until Monday.
https://www.bigmacktrucks.com/topic/75204-hub-oil-seal/#findComment-570153
Answer this question...
