Hey all, I normally don't run into something like this that isn't fairly easy to diagnose... But I'm working on a 2018 mp8 that needs parked regen daily. Originally came in shop with whacky exhaust temps during regen.
Dpf filter was junk. Replaced filter and new 1 box. Exhaust temps during regen look great, soot drops to 0, but rises quickly during the day.
I replaced the Dpf diff pressure sensor and all temp sensors during this process. Engine runs great. Vgt sweep is good, egr cooler not leaking. No exhaust or boost leaks. A little stumped!
https://www.bigmacktrucks.com/topic/75271-frequent-regen-issue/
3 hours ago, fjh said:
Egr diff sensor ? Venturi ports clogged?
I did check ports and they are clear. Customer wants to go ahead and throw a set of injectors at it. I'm skeptical... I've seen bag injectors cause funky regents, but I haven't seen them cause frequent regen. Not on a mack anyway. I did run into that with a Cummins.
https://www.bigmacktrucks.com/topic/75271-frequent-regen-issue/#findComment-571160
Fuel pressure at 7th? Just throwing it out there! Not a guru by any stretch!
https://www.bigmacktrucks.com/topic/75271-frequent-regen-issue/#findComment-571164
