Evening all I’ve managed to do the first run out in the cruise liner ( yippee ) the steering is very heavy. I’ve checked the oil level and it was low so topped it up. I’ve greased everything up all ujs and king pins. Is it worth dropping the oil out of the steering box and draining the system and put all fresh oil in or what do people recommend to do ? Cheers everyone
https://www.bigmacktrucks.com/topic/75273-power-steering-really-heavy/
Does the steering pump have a filter inside of it ?  I dont know what type it is, but some older trucks i worked on had belt driven pumps with a filter in the resevoir.  I have never seen a truck like yours in person
Check the lines for restrictions. Those break down internally and will restrict flow in a handful of ways.. if the lines are hard as steel you may just want to build new lines..
Joey I was talking to Nathen earlier and told him I read on BMT somewhere the power steering on these use engine oil not hyd fluid.Can you confirm is this correct??
Paul
Yes. In that year. However. TRW systems in my time use ATF, and Sheppard use 15W40..  of course I make it sound simple.  I expect some other variants to be posted..  i am not well versed on many systems.
Thanks for that.I read on here that was the case.I found it strange because Id never heard of it before....
Paul
Yes sir.  Really all oil is hydraulic fluid, really all fluids.. i have zero knowledge on trucks outside the States..  my guess is the pump construction determined the oil grade..  of course i have seen systems filled with the wrong oil or its mixed, and it still worked.. theres a couple guys here that can quote the book on this.. They are very smart..
