  • 0
Headlight marker light issuse
Question
16 answers to this question
  • 0
Ok.  That switch can cause issues. Leave it unplugged for now. Do your head light wires still run behind the oil filters? If so, look at 'P' clamps to see if thy are cutting into the wires, as well as rubbing the block, also, check where the go around the steering box for wear.
  • 0
Ok.  Im not sure at this point, assuming the headlight switch and turn signal switch is ok. Van you unplug the turn signal switch and try again
Answer this question...
