Hi Everybody,
Previous owner ran water rather then coolant and its a nice rusty hue and i am planning on doing a flush of the cooling system consisting of:
*drain water out
*put in fresh water, run engine then drop again after 20 minutes
*if dirty water coming out then repeat previous process
*if clean then put in coolant system flush with fresh water and follow instructions
*flush system out of with fresh water
*put in distilled water to flush out all/most of the fresh water and run engine for a 20 minutes
*Put coolant concentrate mixed to highest level with distilled water
This will be fine BUT i have a concern and that is the heat exhanger tube for the oil, i know they can fail and have been toying with the idea of removing it and cleaning it before i put in fresh coolant.  Also tossing up taking the radiator to a radiotor place to get it reconditioned as a precaution.  What is everybodies thoughts?
Thank you in Advance,
Chris
Without seeing the issue up front, can you run several cycles of dish washer powder until its clean. We use Cascade in the states. There are other brands to use.
  On 4/5/2025 at 9:48 PM, Joey Mack said:
Without seeing the issue up front, can you run several cycles of dish washer powder until it’s clean. We use Cascade in the states. There are other brands to use.
Expand
Put premixed coolant in save your buying distilled water!
would you guys be concerned about the state of the radiator or heat exchanged ?  Im building the truck to do long runs and it gets hot here (40+ degrees celcius) and concerns are running in my mind as to weather to just replace the radiator and heat exchanger?
Yes. There are some small steel lines needed to bleed air, do have pictures of the front if the engine, including the left front corner and the water pump, and the right front  corner including the lower corner.
  On 4/6/2025 at 3:40 AM, Gorilla said:
if it does not have one can you retrofit them to the etech?
Expand
Yes, they just get plumbed from the pressure side to the suction side of the waterpump.  Most bigger filter mfg sell the spin on filter heads.
If I were you, I'd install the filter and run it for a while. If you have overheating problems change the radiator. That way you give the filter a chance to work, and not put a bunch of crap into the new radiator from the rest of the cooling system.
Coolant filter are a bypass type filter, meaning they can plug and cause no running problems. If you notice the filter is cool after running, the filter is plugged and you need to replace it. (doing its job). Once the crap is out of the system, the filter will keep new stuff from building up..
Expand
Ill take some pics tomorrow when im at the truck, very little information online on the Quantum and its unique to both renault and macks so fun times  hahaha ;)
Expand
Going to look into it today, although i dont have overheating problems just coolant is either really old and rusty or its water and im not game to taste it and see if it is coolant hahaha.  Plan is to put a camera into the radiator once ive cleaned it to see what its like inside and then decide weather to replace the radiator.  Truck is not overheating as such, more so preventative maintenence.
I had the same issue with my pickup, still having it actually. Previous owner put water in and I never knew until I checked recently. I pulled the lower radiator hose and flushed it using a garden hose until it was completely clear. Did the same with the heater core, which we knew would eventually clog being the highest point in the cooling system on my truck. It eventually plugged so solid that no heat at all would come out of the vents, so that ended in a heater core replacement. I plan to keep flushing like that every once and a while, because I know it's still nasty in there, but I've been afraid of running anything through it other than water. Think Cascade powder is good to use?
