Have 07 Ai 427 that the boost drops off when pulling hard loaded. Boost will be 30+ and fall back to 20-22 then will come back and fall out again. No change in rpm’s just boost psi. Boost Does not drop out when empty even when accelerating hard. No lights or codes coming on when boost drops. Truck has 148,000 original miles 13 speed and 4.17 rears. Any help be appreciated on what might be going on?
https://www.bigmacktrucks.com/topic/75379-07-mack-granite-ai-427-boost-drop/
Do you hear the sound of air rushing through a leak ? Im curios about a boost leak that opens when pressure is up. What type of turbo do you have and does it have a waste gate?
