Hey fellas, has anyone got a bit of info on what faulty lifters or cam sounds like in a mack e6/e7
i have done value adjustment, check for bent push rods, removed and striped rocker shaft and all is ok
the tick is loudest on cylinder 2 exhaust rocker
The ticking sound almost goes away when engine just starts to warm up, which I thought if it was lifters the ticking sound would stay all the time?
https://www.bigmacktrucks.com/topic/75443-mack-e6-ticking/
when draining the oil/ use a kitchen strainer under plug .strainer usually will catch lifter  particles. when Mack went to oversized pans ; what a pain -in =ass . helps to make sure pan HAS to be removed. and we all know oil warm when draining helps.
https://www.bigmacktrucks.com/topic/75443-mack-e6-ticking/#findComment-574249
