Been seeing some oil dripping from the air tank lately and brake chambers. I assume its a seal on the air pump. anybody know where would be a good place to start.
Air compressor is tired. The piston rings in the compressor are probably worn and allowing oil to get pulled up into the cylinders, then the oil gets mixed with the compressed air and delivered to the air tanks.
https://www.bigmacktrucks.com/topic/7736-r600-oil-in-air/#findComment-28076
