Do you mean from the factory or just jacking out the rack?
Glen I was sent this by mackcl96 Don't no how true it is cause I never seen one.
Hello,
Mack did a E6-400 in 89
Mack also had E7-400 90
Mack always said 350 tops on E6 but they wanted to see what would happen at 400HP before they stop using the E6 altogether. It was a probably a inside bet with the tech guys at Mack.
I don't know how they made out but if it was not going to work they would have a E7 to save the customer.
If your like me you never seen one but dosent make it so.
They were few and far between if it did happen.
https://www.bigmacktrucks.com/topic/7842-hybrid-engines/#findComment-29148
