Hello All!
I am looking for information about the set up on a C model that has two Tachometer, one on the pump panel and one in the dash. I know that this was an option on this model but mine did not come that way. The previous owner added an electronic tachometer but I have a second cable tachometer. Does anyone know where the split is made to connect the one in the dash? How long the cable going to the dash? If any one has any info that would be great!
https://www.bigmacktrucks.com/topic/7964-1965-c95/
  • 3 weeks later...
I think the cable drive tach runs off of the distributor. Check and see if the distributor has a second output. If it is diesel it may drive off the alternator. It depends on the engine. A dual distributor ignition may use one for each tach. If it is gas power and you want a second tach I would use a Stewart Warner as they look correct B) and were used by a lot of manufacturers as original equipment. Hope it helped some. :idunno:
#1 on A-model registry
https://www.bigmacktrucks.com/topic/7964-1965-c95/#findComment-30333
The tach drive on our 464 gas comes off the cam near the dual distrubutors, then goes to a duplex/reducer to slow the speed for the long cable going back to the pump panel, the second output on the duplex/reducer is for the tach on the dashboard. If you need the reducer/duplex drive it should still be available at a speedometer shop. see if 66-C05 F can post the picture, if not I can take a picture of the duplex/reducer
Firemack
https://www.bigmacktrucks.com/topic/7964-1965-c95/#findComment-30365
  • 1 month later...
Thank you everyone, you have given me somewhere to start.
Fireflem
https://www.bigmacktrucks.com/topic/7964-1965-c95/#findComment-31858
