Does any one no what it would cost to have a cranshaft cut and to replace the number one pushrod replaced on a 1989 mack E6 4 valve 350.
Motor is in a Superliner that is pretty cherry!! A freind ones the truck and says he would sell it to me for $3500.00
Thanks for any in put, Mike. :mack1::MackLogo::bulldog3:
Edited by macknutt
https://www.bigmacktrucks.com/topic/8188-crankshaft-and-pushrod/
Macknutt
I turned the crank on the 464 6 cylinder gas engine 2 years ago, it cost about $250 and to recondition the rods was about $250. The bearing sets were about $500, gasket set was about $300. While I was in there did the piston rings for $368, and the clutch was about $500. Painted the engine at a local machine shop was $300.
Hope that helps,
Firemack
https://www.bigmacktrucks.com/topic/8188-crankshaft-and-pushrod/#findComment-30237
Crank and push rod???? dosent add up in my mind!
or crank and conrod please clarify.
you pull Engine out the crank out??
I'd be carefull!
https://www.bigmacktrucks.com/topic/8188-crankshaft-and-pushrod/#findComment-30239
