  Basil700 said:
Hello,
Can anyone help a new Mack man decipher the numbers on my Mack rears from the picture. The ratio 5.73 is cool but the rest of the numbers I don’t understand.
Im trying to find a correct parts diagram for this setup to see what parts are available.
Any help appreciated
Barry
The C92 is the series i do believe, thats a low ratio, it must rev hard. i have 5.32 and 5.13 diffs sitting there and there still going to be to low.
i am at the unit tomorrow, is your truck close to unit? i need to see how good or bad the hood line is where it meets up with the cab.
regards Grant
https://www.bigmacktrucks.com/topic/8212-rear-axle-numbers/#findComment-30300
  MrDave said:
Basil, if you can post a fax # I can fax arrangement and parts list hopefully helpful
Dave, Im not sure where you are but if the the US the fax number is :0011 61 8 6437 5920
Within Australia : 08 9437 5920
Attention : Barry K
I appreciate your help.
Regards,
Barry
https://www.bigmacktrucks.com/topic/8212-rear-axle-numbers/#findComment-30320
  Basil700 said:
Hi Dave,
Im not sure why It didnt work. Thankyou for trying. It might be our machine playing up.
Regards,
Barry
try +61 8 6437 5920 my girl friend works in chicago, the 0011 doesnt seem to work all the time!
Grant
https://www.bigmacktrucks.com/topic/8212-rear-axle-numbers/#findComment-30603
  ducky698 said:
scan an email it maybe?
is your land line set up for international calls? am sure you have to set it up with your provider.
regards Grant
Good point! I tried calling a friend in Germany once and the call didn't go through. Went to work and called from there and it worked. Turns out my home phone isn't setup for international calls.
-Thad
https://www.bigmacktrucks.com/topic/8212-rear-axle-numbers/#findComment-30777
