Hey guys me and my uncle are in the middle of changing engines out on his 62 B model. I have two serial numbers for the engines and i was wondering where i could find some info on them, like HP and other stuff like that.
The older engine SN: ENDT673-87-8
Newer Engine SN: ENDT673C-2G4167
Any info would be appreciated!
https://www.bigmacktrucks.com/topic/8454-engine-spec-question/
On the ENDT673 I have HP ratings of 205 560 lbs.of torque and 211HP and 605 lbs. of torque. No sure of the ENDT673C but I think that was 250 HP. Neither of those engines were factory in a B62 it was equipped with a EN464 gas with 170 HP and 370 lbs. of torque. Maybe someone else will have more accurate #'S for the ENDT673C Joe D.
https://www.bigmacktrucks.com/topic/8454-engine-spec-question/#findComment-31389
Thanks for the info! We are going to put the C in because he had it laying around and we are using a Mack intercooler and making it intercooled. Should be interesting with it all done!
https://www.bigmacktrucks.com/topic/8454-engine-spec-question/#findComment-31391
