I know this is going to sound like a stupid question to all you veteran mack owners but I'm just a newbie on owning one. I have a 300 e-6 , how do you tell if it's a 2 or 4 valve. Don't pick on me too bad. Lol. Aww go ahead I've got broad shoulders , I can take it. Lol. :pat:
Welcome aboard Greg! You will find we are all quite friendly so you dont have to worry bout being a total n00b :D
Go to this topic I started a while back. You might find the info you need there.
As a quick note, someone said all the 4 valve heads had front mounted after coolers, the 2 valve had the side mounted after cooler. Might be wrong but read up anyways.
-Thad
https://www.bigmacktrucks.com/topic/878-2-or-4-valve/#findComment-4477
Look at the valve covers. If they are the sort of flat looking aluminum ones, then its a 4 valve. If the valve covers are the rounded looking stamped steel kind with 3 hold down bolts on top, then its a 2 valve engine. theres lots of other differences too but thats the easiest way to tell.
https://www.bigmacktrucks.com/topic/878-2-or-4-valve/#findComment-4481
Another way to tell is the injector lines go in the head under the exaust manifold on a 4 valve, 2 valve injector is on the top left of the engine.
https://www.bigmacktrucks.com/topic/878-2-or-4-valve/#findComment-4488
Thanks Thad, for the info , and your right everyone on here is friendly and knowledgable, thanks everyone!
https://www.bigmacktrucks.com/topic/878-2-or-4-valve/#findComment-4499
Can't make any money with a broken Peterbilt, or Kenworth; So I expect he spends every waking hour fixing those.
https://www.bigmacktrucks.com/topic/878-2-or-4-valve/#findComment-4505
LOL just a funny thought. get a wrecked Mack with a good frame and drive train. Get a good pete cab and hood slap it on and you will have one of the most reliable petes on the road lol.
-Thad
https://www.bigmacktrucks.com/topic/878-2-or-4-valve/#findComment-4536
Actually, The only one......
https://www.bigmacktrucks.com/topic/878-2-or-4-valve/#findComment-4538
