Looking for a source to purchase grab handles, railings and recessed latches for compartment doors on a 1966 Mack C-95 open cab pumper. The existing handles, etc., are chrome and in a rusted/pitted state. I know I can likely have these parts re-chromed, but it may be cheaper to look for new items.
Regards,
Gary M. Belt
Manassas, VA
https://www.bigmacktrucks.com/topic/9066-grab-handles-compartment-latches/
Gary,
The grab handles and railings are Mack specific, and not easy to find. You may be able to find stainless steel tubing to replace the railing, but the fittings are Mack. If you are open to a non original look you can go to tow truck accesories web-sites that have grab handles and can use them but will not be the same Mack Fire truck look. I looked around and finally had mine rechromed.
The door handles are from a company called Eberhard, they are still in business and may be able to replace the handles you have.
Firemack
Regards,
Gary M. Belt
Manassas, VA
I HAVE THE 4 FLUSH MOUNT EQUIPMENT BAY LATCHES
OFF A 62 MACK C95. I ALSO HAVE TWO SMALL
GRAB HANDLES OFF THE ENGIN HOOD.
THE SIDE GRAB HANDLES ARE STOCK MACK
COMPONENTS WITH CHROME PIPE SECTIONS
CUT TO LENGTH. I WILL GET YOU THE VENDOR
OF THE CHROME PIPE (BETTER THAN ORIGINAL)
AND CHEAP ON TOP OF THAT.
I TOOK MY PIPE , WITH A SAMPEL TO MY
ELECTRICAL CONTRACTOR AND THEY
PUT THE BENDS IT FOR UP THE BACK. SLICK!
DAVE CASEY
maxbrother@aol.com
Del Rio,Texas
  Firemack said:
Gary,
Firemack
Thanks for your help; I'll look them up.
Gary M. Belt
Manassas, VA
  • 4 months later...
