We have become a Master Distributor for Steel Shield products!
Steel Shield makes top quality oil additives and other oil products such as Drill & Tap Shield and Weapon Shield CLP. The company is located in Pittsburgh, PA and uses only U.S. oils for their blends. We will have a test machine at Macungie this year to prove the quality of this stuff! It is impressive!!
Check out the product information in our new store...
Steel Shield
Steel Shield uses advanced boundary film technology to practically eliminate friction caused by metal to metal wear. In return, this cuts down on heat and wear, plus it improves fuel economy!
If you own guns, Weapon Shield is the single best cleaner, lube and protectant that you can get. Period. Our boys and girls in Iraq are throwing their USGI CLP's away after trying this stuff...it's that good!
I would NOT recommend it if I didn't believe in it!
https://www.bigmacktrucks.com/topic/9083-steel-shield-products/
