My batteries are run down in the B61T. Is there another acceptable way of charging the batteries with out disconnecting them and charging individually? I have 4 batteries on a 12 volt positive ground system. The batteries are 6 volt which would mean to me that it is a series - parallel combination. Any advice appreciated.
George
https://www.bigmacktrucks.com/topic/92-battery-charging/
The only way to get a good charge on ALL batteries is separately. If you do them as a unit, one may take a good charge and the rest be marginal(depending on overal condition of battery).
Charging at 12v across two batteries might get it running again, but from past experience and from what I have heard from battery people it's better to do them individually (at 6v).
https://www.bigmacktrucks.com/topic/92-battery-charging/#findComment-305
