normal for a cold engine to smoke on cold start in the colder months. Need to know how hot it really was. transmissions can reach 180 deg on hard long pulls. all depends if it has a cooler or not. lots of friction in those meshing gears. did you check the oil level?
https://www.bigmacktrucks.com/topic/9389-motortranny/#findComment-35190
oil level was up.temp wise i'm not to sure to hot to hold on to very long 15-30 secs. this was about 20 mile pull 35-40 deg out side temp.
https://www.bigmacktrucks.com/topic/9389-motortranny/#findComment-35192
