you a correct, the tec brake has all the same parts as the jacobs brake. All parts are available through tec brake's web site. You can get a rebuild kit for it, about a 100 bucks. I am looking for some of the little discs that go ontop of the valves, there are two sizes the ones I have are the larger ones. At 25 bucks a piece they are a bit pricey.
Fred
15 gears...no waiting!
Sweet! and only $100! Mine doesn't seem to work right. I put it on and it takes a long time to start to work and then doesn't seem to stop the engine really quick. When you shut it off and turn it right back on it takes quite a while for to do anything again. I installed it by the book so am not sure whats wrong. Figured it needed a rebuild and I figured the parts would be expensive as could be, but I am wrong on 1 part.
Any advice helps alot.
Thanks,
Bob
